AUTO SHUTDOWN GUIDE Updated 05/11/02 by Tim B @ OCWorkbench.com This guide is for boards which don’t have the automatic shutdown feature built into them - i.e. my K7S5A, as the bios only has control over the post sequence it would be good if windows could shutdown the system when it gets to hot or too much voltage, This guide makes use of the original shutdown exe available from within windows xp or an alternative can be downloaded here http://www.budja.com/shutdown As you may know the K7S5A doesn't have the temperature shutdown feature on board however the same effect can be achieved through software, WindowsXP has its own utility built in called shutdown which can remotely shutdown or restart other computers on the same network, To get your computer to shutdown on high temp for example just do the following: - Either use the built in shutdown.exe or download the one above (which may work with other windows o/s' although I tested it on win98se and it didn't)
Configure Motherboard
Monitor 5 Step1 Step2 Step3 Tha available are (using windows xp util - the download has similar options)... Usage: shutdown [-i | -l
| -s | -r | -a] [-f] [-m \\computername] [-t xx] [-c "c No args Display this
message (same as -?) Step4 Apply the settings and
you're finished! The above method can also be used for voltage alarms and fan
speed alarms using the same principal, If anyone has this working on Win2k/NT
let me know! Note: I actually use MBprobe to shutdown the system on critical temps and has worked once for me when the power plug once fell out on my nice Volcano7+... MBProbe can be seen
here.. Tim B. By BbrainFor Win9x/ME/2k : "RUNDLL32.EXE user,exitwindows" You can also create a shortcut and put this command line on it. *Don't use the "" on the command line best regards
