USB Header Guide Updated 05/11/02 by Tim B @ OCWorkbench.com Warning Incorrect connection of the usb header may result in damage to the boards USB header. See this link for the
K7S5A USB header pin out. Original Thread. Related Links. ECS USA
By Fineous Pin arrangement of front
USB on k7s5a: 1 ___ 2 (towards front of case) USB header pin out for K7S5A Signal name __________
pin From the ECS K7S5A FAQ The K7S5A has a header for connecting two extra USB ports, but you need to buy an extra cable. The cable should have two USB ports on one end and a motherboard connector on the other. You also need to know what each pin connects to: 1 --- 2 Red (+ 5V)
