BIOSTAR
iDEQ200P nF3 150 SFF Barebone Gallery (3)
One thing we noticed about the BIOSTAR IDEQ 200P is that it has all the cable connectors labelled clearly. Whether it is for HDD, CDROM, etc are clearly labelled. Installation is simplified because all the cables are already laid properly for you.
The laid IDE cables that comes with the box
The power connector that is all connected.
We used a Tyan Radeon 9700Pro for the tests. The only trouble during installation is that we must remove the HDD/CDROM/Floppy brakcet because the card is too tall and it is being blocked by the bracket. This is a bit troublesome for me since I need to take out the card to do other tests on boards. |
