DFI LAN Party
865PE
Gallery (2) Oveclocker 18 Dec
2003
5 PCI and 1 AGP slot. We see that the CMOS
battery and jumper has shifted to the top left corner of the mainboard. On
the rear you can see 2 IEEE 1394 connectors for external bracket.
A 3 phase voltage regular design is
implemented. The +12v ATX connector is found near the Socket 478 while the
power connector is at the other end of the board.
Over here,
you see the VIA VT6306 Firewire controller chip, Intel82801EB South Bridge
supporting 2 SATA ports, Silicon Image SATALink Sil3112A chipset supporting
2 SATA RAID ports (for RAID 0 or 1). The BIOS, CMOS Battery, Power and Reset
Switch
2 IDE channels, Floppy connector, Power
connector
Supports dual channel memory interface
Supports up to 4GB memory (unbuffered DIMM)
Uses PC1600 (DDR200), PC2100 (DDR266), PC2700 (DDR333) or PC3200 (DDR400)
DDR SDRAM DIMM, 2.5V type
4 x 184-pin DDR SDRAM DIMM sockets
Intel 865PE
North Bridge supporting Dual Channel DDR400 with Pentium 4 400/533/800FSB
processors
The back
panel - PS/2 Mouse & Keyboard. Com1, Lpt1, LAN, 4 USB, 1 Firewire, audio
ports., S/PDIF in (red), S/PDIF out (yellow) and audio ports
