Gigabyte 7VAXP-A Ultra KT400A Review (7)
Benchmarking All boards running in SYNC DDR333 (166/166) otherwise specified. The FSB of the various boards are : Gigabyte 7VAXP-A Ultra : 166.92Mhz Quake 3 Demo 001
Quake3 demo001 is a memory intensive application. The Gigabyte 7VAXP-A Ultra
performs impressively with a score of 241 fps which is 4% higher than the KT400.
On the average SIS 746/746FX boards are 2-4 fps slower than the KT400A. 3Dmark2001 SE Build 330 In 3Dmark2001SE, we again see that Gigabyte 7VAXP-A Ultra performs very well
with a high of 11149, just 200 points behind the nForce2 boards. It has major
improvements over the KT400 and is right behind the nForce2 boards when run in
Async DDR400 mode. Comanche 4 Demo In Comanche 4, we see a similar pattern. It seems that nForce2 boards does
has an advantage in 3D applications over the other chipsets by a small
percentage. The Gigabyte 7VAXP-A is on par with the SiS 746FX boards. leading by
less than 1fps. |
