Users of the Shuttle
SS40 must have been waiting for this AMD box for a long long time. With the
recent proven performance lead of nForce2 in the AMD mainboards, Shuttle
introduces its long awaited SN41G2. SN41G2 is an integrated board using the
nVIDIA's nForce2 IGP chipset that provides not only Dolby Digital audio, it also
includes a dual view VGA with on board GF4 MX equivalent video performance. With
the nForce2 Dual Channel DDR technology, it brings games to another level with
better overall system performance
This box only measures (L)300*(W)200*(H)185 2.85Kg
(N.W.) and a weight of 4.48Kg (G.W.) and it definitely suits most
modern homes. Below is a list of the specifications of the box followed by the
gallery.
Specifications
Form Factor: Shuttle Form Factor
CPU Support
AMD Duron CPU with 200 MHz FSB
AMD Athlon CPU with 200 / 266 MHz FSB
AMD Athlon XP CPU with 266 / 333 MHz FSB
Chipsets:
North: nVidia nForce2 Crush18G
South: nVidia MCP-T
Memory:
2 x 184 pin Dual Channel DDR SDRAM Socket
Support DDR200/266/333/400 DDR SDRAM up to 2GB capacity
VGA: Build in Crush18G
AGP v3.0 Compliant
Built-in a high performance 256-bit 3D engine
Audio: Realtek ALC 650
AC ’97 v2.2 (supports 5.1 channel) compliant CODEC on board
Support Digital SPDIF In/Out
IDE interface:
2 x UltraDMA/100 IDE Channels Master from MCP-T
80-pin Cable Backward Compatible Legacy ATAPI Devices
ATAPI IDE CD-ROM, CD-R, CD-RW, and LS-120 Supports
IEEE 1394a : Realtek 8801B
Complies with 1394 OHCI specification revision 1.0
Support 400Mb/s, 200Mb/s, 100Mb/s data transfer rate
TV-Out: Chrontel 7005C
Supports PAL and NTSC Systems
Supports Composite, S-Video, and Component R/G/B Output.
Supports maximum input active resolution to 800x600.
Ethernet: Realtek 8201
IEEE 802.3u 100Base-T specifications compliant
10 Mb/s and 100 Mb/s operation
Expansion Slot:
1 x AGP 3.0 compliant slot
- Support external AGP V3.0 compliant VGA device
- Support 4X, 8X AGP data transfer
1 x PCI slot
- PCI 2.2 compliant, 32-bit BUS Master Slots
- 133 Mbytes / sec maximum throughput
Power Management:
APM 1.2 compliant
ACPI 1.0 compliant
OnBoard connectors and jumpers:
3 x fan connectors
1 x ATX main power connector
1 x ATX12V power connector
2 x UltraDMA/133 Bus Master IDE connector
1 x Floppy connector
Clear CMOS
OnBoard Headers:
2 sets of 2x5 pin USB 2.0 header
1 set of 2x5 pin Front Panel IEEE1394a header
CD_In header
Microphone_In header
Speaker_Out header
SPDIF_In/Out Header
Parallel port header
1 set of IrDA Header
