ASrock
K7Upgrade-880 VIA KT880 with 754 Bridge Card 2/7
Benchmarks Front Side Bus is still a valid and important criteria when judging systems performance. We measured the FSB and found that the ASrock runs at 200.5 Mhz FSB half a MHz higher than 200MHz.
Next we used a the Corsair XMS3500C2 512MB and ran the memory benchmarks. As the memory controller is within the CPU, the memory benchmarks are quite consistent with other boards. It scored 3101/3100.
