ASrock K7Upgrade-880 VIA KT880 Socket A
Review 5/7
Benchmarks - Q3 The ASrock K7Upgrade-880 scores 307.2 fps in this test. Although the KT880 chipset is a dual channel chipset, the performance is a bit weak due to the ram timings used. Some of the NF2 boards are running higher than 200MHz and that has some impact on the overall performance.
