| CPU Host
frequency can be set to AUTO or Manual. When set to Manual, you can adjust
it from 140 ~ 300MHz FSB at 1MHz stepping. AMD Cool N Quiet is enabled by
default. |
The Memory Configuration has lots of options.
The memory clock can be set to operate at 100,133,166,200, that is to say
you can run memory at 166, that would be 200:166 Async mode.
Most users would be interested in these
settings like the CAS Latency, TRCD, TRAS and TRP. In our tests, we set
them to run at CAS 2, 5-2-2. We left the others at default. |
| AGP Aperture
size is set to 128MB, AGP Data rate at 8x, Fast Write was off by default,
we enabled it. |
In the
Hypertransport configuration, we set HT Width to 16 bits, HT speed to
800MHz, There are two other options which we left at default. |
