Gigabyte GO-W0808A 8x DVD+/-RW Drive Review (1)
Bluetooth 2 Sep 2004
Specs
  • High Performance
    8x speed writing ability on DVD+/-R, 4x speed writing ability on DVD-RW/+RW, 40x speed writing ability on CD-R discs, 24x speed on CD-RW discs. 40x speed CD-ROM and 12x DVD-ROM reading performance.
  • High Transfer rate
    Support Enhanced IDE interface connection and PIO mode 4(16.7 MB/sec), DMA mode 2 (16.7 MB/sec)& UDMA mode 2(33.3 MB/sec) data transfer.
    High Compatibility
    CD Audio and CD EXTRA, CD-ROM (Mode 1), CD-ROM XA (Mode 2, Form 1 and Form 2), CD-I, Photo CD, Video CD, CD-TEXT. Supports writing modes of TAO, DAO, SAO and packet writing
    DVD-ROM, DVD-Video, DVD-Audio, DVD-R/RW single/multi border(s), DVD+R single/multi session
  • Stability
    SMART-BURNR® function can avoid buffer under run as well as get the best writing quality by smartly adjusting writing strategy.
    VAS (vibration reduction system) enables to absorb the vibration during operation.
  • Malfunctions Prevent Mechanism
    If the load/eject mechanism is blocked during an eject, the mechanism should return to the closed state with no damage to the drive or degradation to the loading mechanism.
    3-way eject functions: software, front panel press-button and manual emergency eject hole.
  • Durable
    MTBF (70,000 hours); High standard Tray Cycle Test : 30,000 times of continuous cyclic operations.(One cycle is an open/close.) Dust-Proof Structure: The drive incorporates a slot covering mechanism to exclude air flowing through this opening when the drive is operating.
Discuss >>>
