Scythe Samurai
SCSM-1000 Heatsink Review (2)
Bluetooth 4 Aug 2004
Specs
Model Name:
SCSM-1000
Manufacturer:
Scythe Co., Ltd., Japan
Compatibility:
Intel:
Celeron (socket 478) all speeds
Pentium 4 (socket 478) all speeds
AMD:
Duron (socket 462) all speeds
Athlon (socket 462) all speeds
Athlon XP (socket A) all speeds
Athlon 64 (socket 754) all speeds
Athlon 64FX (socket 754) all speeds
Opteron (socket 939) all speeds
Opteron (socket 940) all speeds
Fan Dimensions:
80 x 80 x 25mm
Heatsink Dimensions:
83 x 65 x 38 mm
Combined Dimensions:
98 x 84 x 95 mm
Fan Speed:
1300~3400rpm (with rheostat)
Air Flow:
13.6CFM @ 1300rpm ~ 34CFM @ 3400rpm
Fan Noise Level:
16dBA @ 1300rpm (lowest); 37dBA @ 3400rpm (highest)
Weight:
605g
All Copper Heatsink
To maximze the cooling
performance, Samurai CPU Cooler has the 100% solid copper heatsink
Easy Installation
Scythe's unique R.C.C.M. (Rigid Core Clamping Mechanism) makes installation
quick and easy
Super Quiet
At its lowest setting, the fan is nearly inaudible (16 dB @
1300rpm)
Cross-Platform Compatibility
Compatible with socket 462/478/754/940
Great Value!
Affordable and reasonable price.
