ASrock 775Dual-915GL Mainboard
Benchmarks 2/7
Benchmarks Before you read on, it is important to understand that the benchmarks done are more of a comparison of the AGP and PCI-E performance with boards that are of a similar class. In our tests, we benchmarked the board with 6600GT and compared it with a full fledge EPoX 915P board that uses DDR400 memory. This would give you a clear picture of the difference between a native PCI-E X16 versus a derived PCI-E x 4 performance. Front Side Bus is still a valid and important criteria when judging systems performance. We measured the FSB and found that the boards run at 200.9Hz. The following readings are obtained using CPU-Z.
We used a pair of TwinX Corsair RAM and runs it at CAS 2, 5-2-2 and below are the memory benchmark scores obtained. It is not surprising that with integrated graphics, the 775Dual-915GL will score a bit lower in this test. The EPoX on the other hand only get 4679/4672.
