ASrock
939Dual-SATA2 ULi M1695 with AGP 8x (9800XT) Performance Review
2/6
Benchmarks Front Side Bus is still a valid and important criteria when judging systems performance. We measured the FSB and found that the board runs at 200.0 exactly on the dot. The graphics card used is Gigabyte's Radeon 9800XT with Catalyst 4.6.
We used a pair of TwinX Corsair RAM and runs it at CAS 2, 5-2-2 and below are the memory benchmark scores obtained. We can see from the chart that the BIOS has tuned the performance very well and it is comparable to other mainboards based on the same chipset. As we have mentioned before, ULi M1695 uses tunneling through HTT and support the AGP 8x natively from the south bridge. This technique is unique and we are interested to see if the results are as good as native AGP boards.
