ASrock
939NF4G-SATA2 (GF6100)
Benchmarks 2/7
Benchmarks In this comparison, we compare the ASrock 939NF4G-SATA2 against the other boards using various chipsets. We will also compare the scores obtained using its integrated video (128M) especially with the ATI RS482 chipset. All tests are done using the Corsair TWINX memory running at CAS 2, 5-2-2, 1T. The Default Clock is still a valid and important criteria when judging systems performance. We measured the default clock and found that the board runs exactly at 200.0MHz. The following readings are obtained using CPU-Z.
From the chart below, it is not difficult to see that the integrated chipsets, be it the GF6100 or the ATi RS482, memory benchmarks are slightly lower than the discrete ones. With lesser memory, it would impact on the memory intensive 3D programs.
