ASrock
939S56-M SiS 756 Review 2/7
Benchmarks Front Side Bus is still a valid and important criteria when judging systems performance. We measured the FSB and found that the board runs exactly at 200.9MHz. The following readings are obtained using CPU-Z.
In the first test, we used a pair of TwinX Corsair RAM and runs it at CAS 2, 5-2-2, 1T timing. This board scored 6005/6064 which is on par with most other K8 chipsets.
