ASrock
P4Dual-915GL Mainboard Review 2/7
Benchmarks Before you read on, it is important to understand that the benchmarks done are more of a comparison of the AGP and PCI-E performance with boards that are of a similar class. This is because P4Dual-915GL is the only board based on 915GL chipset that uses a Socket 478 processor and supports PCI-E and AGP slots which are derived from PCI and PCI-E x 1 interfaces on board. (915GL by itself does not support any graphics interfaces). Front Side Bus is still a valid and important criteria when judging systems performance. We measured the FSB and found that the board runs at 199.9MHz which is slightly below the expected 200.00. The following readings are obtained using CPU-Z.
We used a pair of TwinX Corsair RAM and runs it at CAS 2, 5-2-2 and below are the memory benchmark scores obtained. Compared to the 865PE counterparts, the P4Dual-915GL is a bit lower probably due to the fact it has to side aside the PCI for AGP interface.
