Benchmarks
The system is run
twice, once with a Powercolor X850XT PE card. The second is in CrossFire mode
using a Powercolor X850XT PE + Powercolor X850XT CrossFire Edition card. When
run with a single card, the card must be inserted into SLOT 1 and by default it
is set to 16x. For CrossFire mode, the BIOS needs to be adjusted to support Dual
8X mode.
For completeness,
a measurement of the Default CLK is taken and it is recorded as 200.5MHz.
The following readings are obtained
using CPU-Z.
The Memory Benchmarks basically
gives us an indication on how much bandwidth is there for the I/O. The higher
the numbers, the better it is. This is especially true for graphics intensive
applications.
Discuss in
Forum
