In DRAM configuration, a
number of options can be set. In our case, we set the board to run in sync
mode, CAS 2, 5-2-2, 1T cmd. |
Memclk allows
you to run CPU:DRAM in sync or in ASync mode of DDR 333,266 or 200. |
LDT bus frequency,
sometimes also known as HT multiplier. We have choices of 1GHz (default),
800, 600, 400 and 200 |
GFX0 link width. If
a single graphics card is used, it should be set to X16 for maximum
performance. If crossfire is enabled, it should run in 8x + 8x mode. |
