We ran the board at aggressive timings of
CAS 3, 12-4-4, command and data bypass set to Enabled. This gives the best
performance so far. |
CPU multiplier can be set lower to 14x on
the P4 3.6GHz (800FSB) processor. |
FIX PCI as you might want to call it. It
can be fixed to 33, 37.5 or 40.0Mhz |
CPU Clock can be adjusted up to 450MHz. |
CPU:DRAM for ASync operation. As our
Corsair ram is rated DDR2-533, it is actually running at a ratio of 400:533 |
Vcore voltage can be adjusted to +75mV |
Dimm Voltage can be set to +150mv for more
stability at aggresive timings |
