ASrock 775Dual-915GL Mainboard
Benchmarks 4/7
Benchmarks - 3Dmark2001SE/3DMark2003 In this category, we tested the DX8 benchmark. EPoX 5EPA+ scored 18258 and the EPoX 5LWA+ scored 19109 which is 750 points higher. The difference is not a lot as we noticed that the FSB is 201.8 instead of 200.9.
In 3Dmark2003, the scores are more significant. Comparing with the 5EPA+ which uses DDR 400 running at CAS, 2-5-2-2, we are getting a 280 points and 357 points higher using DDR2-533.
