Foxconn
Winfast 6150K8MA-8EKRS Socket 939 (GF6150) Benchmarks
2/7
Benchmarks In this comparison, we compare the 6150K8MA-8EKRS against the other boards using various chipsets. We will also compare the scores obtained using its integrated video (128M) especially with the ATI RS482 chipset. All tests are done using the Corsair TWINX memory running at CAS 2, 5-2-2, 1T. The Default Clock is still a valid and important criteria when judging systems performance. We measured the default clock and found that the board runs exactly at 200.0MHz. The following readings are obtained using CPU-Z. From the chart below, it is not difficult to see that the integrated chipsets, be it the GF6100, GF6150 or the ATi RS482, memory benchmarks are slightly lower than the discrete ones. With lesser memory, it would impact on the memory intensive 3D programs.
