Foxconn
Winfast NF4K8MC-ERS NF4 Mainboard Reivew 2/7
Benchmarks Front Side Bus is still a valid and important criteria when judging systems performance. We measured the FSB and found that the board runs at 200.9MHz which is within the range of 200~201MHz. Although a few points might be insignificant, the results might differ quite a bit in the actual CPU speed. The following readings are obtained using CPU-Z.
We used a pair of TwinX Corsair RAM and runs it at CAS 2.5 6-3-3 as we are unable to get it stable with the aggressive timings because the Vdimm of this board is 2.5v (as indicated in the manual). The rest of the boards are running CAS 2, 11-2-2. Below are the scores obtained for ALU and FPU. We can see that they are almost similar because the memory controller is built-in the processor.
