Gigabyte
GA-K8VT890-9 VIA K8T890 PCI-E Mainboard Review 2/7
Benchmarks Front Side Bus is still a valid and important criteria when judging systems performance. We measured the FSB and found that the board runs exactly at 200MHz. In our comparison, do take note that the NF4 boards are all running at around 200.9Mhz or 201MHz. Our board in the test is running at 200.9MHz. The following readings are obtained using CPU-Z.
In the first test, we used a pair of TwinX Corsair RAM and runs it at CAS 2, 5-2-2. This board scored a good score of 6069/6018 (ALU/FPU). Although the memory controller is within the CPU, the higher the scores means the board's stability at aggressive timings.
