SIS
756 Reference Board Reivew 2/7
Benchmarks Front Side Bus is still a valid and important criteria when judging systems performance. We measured the FSB and found that the board runs exactly at 200MHz. In our comparison, do take note that the NF4 boards are all running at around 200.9Mhz or 201MHz. The following readings are obtained using CPU-Z.
In the first test, we used a pair of TwinX Corsair RAM and runs it at CAS 2, 5-2-2. This board scored a good score of 6054/6005 (ALU/FPU). Although the memory controller is within the CPU, the higher the scores means more stability at aggressive timings.
