ULi M1575 South Bridge on ATi RS482
Review 2/7
Pricing of X850XT cards Benchmarks The Default Clock is still a valid and important criteria when judging systems performance. We measured the default clock and found that the board runs exactly at 200.0MHz. All boards are set to run at CAS 2, 5-2-2 unless otherwise stated. The following readings are obtained using CPU-Z.
From the memory benchmarks, it can be seen that the memory performance seems to be a bit slower than the rest of the boards especially when the integrated video is used. That is quite common for an integrated graphics board. When it is paired up with a 6600GT, we can see that the memory benchmarks are almost the same as the ASrock boards. Take note that some of the NF4 SLI boards which we will be comparing with is clocked default at 200.9.
