DRAM Frequency can be set to operate in
DDRII-533 or DDRII-667. Over here you can also set the various DRAM
parameters like CAS, tRP,tRCD, tRAS etc. |
AGP settings can be set if you use an AGP
card. Options include AGP mode, Fast write on/off, aperture size. V-Link can
also be adjusted, in our case, the default is used - FAST. |
