ASrock 775XFire-eSATA2 (Intel 945PL)
Benchmarks 2/8
Benchmarks In this test, we measured the CLK on the BIOS. It seems to be above the default of 200MHz at 201.8MHz. What that means is that our DDR2 modules will be slightly over 266MHz (DDR2-533) when run in ASync mode (default). The modules used are 2 pieces (512M each) of Corsair CMX2x512A-4300C3Pro. rated at CAS 3-8-3-3 538MHz. Graphics cards used are 2 pieces of Powercolor X1300Pro Bravo edition card. The following readings are obtained using CPU-Z.
The following are the memory benchmarks of the two boards in two different configurations- in single card configuration and CrossFire configuration.
