ASrock 775XFire-eSATA2 (Intel 945PL) Intro 1/5
Bluetooth 3 Feb 2006
Introduction
ASrock 775XFire-eSATA2 is the
first board that uses the Intel 945PL/ICH7R board that supports the Presler and
Cediar Mill processors with FSB 800/533. It supports DDRII 5333 with a max
capacity of 2GB.
The board also supports ATi CrossFire technology using a PCIe x16 + PCie x4 (AGI
Express slot). It also supports 5.1 audio using ALC660 codec with HD audio.
Realtek Ethernet LAN is supported too. There are 4 SATA II 3.0GB/s port
supporting RAID 0, 1, 10 , 5 and Intel matrix storage.
As for the rear panel, this board supports eSATA. It allows one to connect
external SATA II HDD through external harddisk box. This dramatically improves
the SATA II performance compared to conventional boxes which uses USB 2.0 or
1394 transfer.
