ASrock 939SLI32-eSATA2 Benchmarks
2/8
Benchmarks In this test, we measured the CLK used by the boards. The ECS KN2 SLI Extreme and Jetway NF4 SLI board runs at a default clk speed of 200.9MHz. Our ASrock 939SLI32-eSATA2 is clked at 201.7MHz. As PCI/PCIe bus are locked, the slight difference in CLK will not result in large difference in 3D results. As this board supports compatible SLI, we configured it to run in SLI mode with Forceware 81.95 with PowerExpress driver. We added a fan on top of the heatsink to improve stability at 1T cmd and ran all tests at CAS 2, 5-2-2,1T. The following readings are obtained using CPU-Z.
The following are the memory benchmarks of the two boards in two different configurations. They're taken at CAS 2, 5-2-2, 1T cmd. All the boards seem to score almost the same.
