ASrock 939SLI32-eSATA2 Benchmarks 4/8
Benchmarks - 3Dmark2003/3DMark2005 In this category, we tested 3Dmark03. The systems are run with Forcware 81.95 as the previous tests for the Jetway and ECS were done using the same forceware 81.95. In SLI mode, the ASrock scored 26277 vs 26660 and 26509. Again, we see that the difference is less than 1%. In single card mode, the differences are around 150 points which is approx 1.1%.
In 3Dmark2005, the scores are 11270 vs 11355 and 11400 respectively. Again we see the NF4 and NF4 SLIx16 platforms leading by 1.1% which is probably due to driver optimisation for the benchmarks. AS for single card configuration, the differences is around 100 points ~1.7%. This result is very interesting as we saw a large difference when we tested the 939SLI-eSATA2 board with a 6600GT, the results are quite far apart. Looks like the optimisations of 3dmark05 with the ever popular 6600GT is too apparent. As for 7800GTX, the difference in Single and Dual gives only a difference of around 1.1%
