ASRock
ALiveNF4G-DVI AM2 board (NF6100) Review Benchmark 2/8
Benchmarks In this test, we measured the CLK used by the boards. Both boards are set to run in SPD mode of the modules which is rated CAS 5, 5-5-15, 2T. Most of ht eother boards are a bit skew off from the standard 200.00MHz. The ASRock ALiveNF4G-DVI runs on the dot of 200.00MHZ. Sometimes a 0.5~1MHz does affect the results.
With that in mind, we take a look at the memory benchmark scores using Sandra 2007. As the memory controller is built within the CPU, the differences aren't that great. ASRock ALiveNF4G-DVI scored a 7438/7499 when paired up with the ASUS 7600GT graphics card. With the embedded video, it dropped to 6460/6489. Interestingly, the AM2NF6G-VSTA which uses a newer 6100-405 does better in this test.
