ASRock ALiveNF4G-DVI AM2 board (NF6100) Review Intro 1/5
Bluetooth 8 Aug 2006
from
various
vendors
Lately, ASRock seems
to be coming out with lots of variations of the AM2 mainboards. In the past
weeks, we have reviewed a number of boards based on VIA, ULi chipsets for AM2.
Today, we take a look at ALiveNF4G-DVI, a AM2 board based on the old chipset
NF6100 (Northbridge) with 410 (Southbridge).
The ALiveNF4G-DVI supports dual channel DDRII-800/667/533 with 4 DIMM
slots with a max capacity of 8GB. It comes with 2 PCI, 1 PCIe x16 and 1 PCIex1.
The board comes with integrated NV44 graphics DX9.0 VGA that supports Pixel
Shader 3.0. It can used up to a max. shared memory 128MB. The board is NVIDIA®
PureVideo™ Ready for accelerating video clips. Most importantly, the board has a
dual VGA output port. - it supports DVI-D and D-Sub ports by independent display
controllers.
The board also supports 2 SATA
II 3.0Gb/s supporting RAID 0,1, JBOD, NCQ and hot plug functions. There is Fast
ethernet, a 7.1 ch VISTA premium level HD Audio using the ALC888 audio codec.The board is Windows®
Vista™ Permium Logo Hardware Ready and AMD LIVE! Ready.
Specs
CPU |
- Socket AM2 for AMD
Athlon™ 64FX / 64X2 / 64 and Sempron Processors
- AMD LIVE!™ Ready
- FSB 1000 MHz (2.0 GT/s)
| Chipset |
- Northbridge: NVIDIA® GeForce 6100
- Southbridge: NVIDIA® nForce 410 MCP |
| Hybrid
Booster |
- ASRock U-COP
| Memory |
- 4 x DDRII DIMM slots
- Supports DDRII800/667/533
- Max. capacity: 8GB |
| Expansion
Slot |
- 2 x PCI slots
- 1 x PCI Express x16 slot
- 1 x PCI Express x1 slot |
| Graphics |
- Integrated NV44 graphics DX9.0
VGA
- Pixel Shader 3.0
- Max. shared memory 128MB
- Dual VGA Output: Support DVI-D and D-Sub ports by independent display
controllers
- NVIDIA® PureVideo™ Ready |
| Audio |
- Realtek ALC888 7.1 channel CODEC with High
Definition Audio |
| LAN |
- Realtek PHY RTL8201CL
- Speed: 10/100 Ethernet
- Supports Wake-On-LAN |
| Connector |
- 2 x Serial ATAII 3.0 Gb/s connectors, support
RAID (RAID 0, RAID 1, JBOD) and "Hot Plug" functions
- 1 x Floppy connector
- 1 x IR header
- 1 x Game header
- 1 x COM Port header
- 1 x HDMI_SPDIF header
- CPU/Chassis FAN connector
- 20 pin ATX power connector
- 4 pin 12V power connector
- CD in header
- Front panel audio connector
- 3 x USB 2.0 headers (support 6 USB 2.0 ports) |
| Rear
Panel I/O |
ASRock DVI I/O
- 1 x PS/2 Mouse Port
- 1 x PS/2 Keyboard Port
- 1 x VGA/D-Sub Port
- 1 x VGA/DVI-D Port
- 4 x Ready-to-Use USB 2.0 Ports (including 2 ports on bundled USB+COM port
bracket)
- 1 x RJ-45 Port
Front Speaker / Microphone |
| BIOS
Feature |
- 4Mb AMI BIOS
- AMI Legal BIOS
- Supports "Plug and Play"
- Supports jumperfree
- SMBIOS 2.3.1 Support |
| Support
CD |
Version) |
| Hardware
Monitor |
- CPU Internal Temperature Sensing
- CPU Ambient Temperature Sensing
- Chassis Temperature Sensing
- CPU Fan Tachometer
- Chassis Fan Tachometer
- CPU Quiet Fan
Accessories |
- Floppy/ATA 133 cables
- 1 x USB+COM port bracket (optional)
- 1 x HDMI_SPDIF cable (optional) |
| Form
Factor |
- Micro ATX Form Factor: 9.6-in x 9.6-in, 24.4 cm x
24.4 cm |
| OS |
- Microsoft® Windows® 2000 /
XP / XP Media Center / XP 64-bit / Vista™ compliant |
Certifications |
- FCC, CE, WHQL |
