AM2NF6G-VSTA comes with something new, it is known as AM2 Boost which claims
to boost memory performance by up to 12.5%. Over at this screen, you can set
the Overclock mode to PCI ASYNC so that PCIe can be fixed at 100 or you may
want to o/c it up selectable to 200MHz. CPU Frequency can be adjusted from
200 ~ 400MHz. Cpu mutliplier options of up to 25x can be chosen. CAS
Latency, tras, trcp, trd, MA timing can be adjusted too (not shown in the
diagram above) |
Memory CLK can be adjusted to run in SYNC or ASync. 4 options are available
as shown above. |
