ASrock AM2XLI-eSATA2 (ULi M1697) Intro 5/5 Bluetooth 27 June 2006
BIOS II
PCI Freq can be set to 33 to 37.5MHz for o/c the PCI bus
VCCM voltage can be set to Auto,Low,Normal or High
CAS Latency, tRAS, tRP, tRCD, MA timing, Burst length can be set to improve
performance. Flexibility option can be enabled to make the system more
compatible with RAM.
Chipset Core Voltage can be set to Auto, Normal or High
