ASrock
K8SLI-eSATA2 (ULi M1697) Benchmarks 2/7
Benchmarks In this test, we measured the CLK used by the boards. The K8SLI-eSATA2 is running at a higher clk of 201.7 and EPOX 8NPA SLI is running at 200.9MHz. As the PCIe bus is locked, the 3D benchmarks would not have much difference. A high CLK will result in a higher CPU test score in benchmarks like pcmark. For SLI tests, the SLI enabling software must be installed prior to the graphics driver (forceware). The following readings are obtained using CPU-Z.
The following are the memory benchmarks of the two boards in two different configurations. They're taken at CAS 2, 5-2-2, 1T cmd. All the boards seem to score almost the same. Note the scores are halved of that of dual channel design.
