ASrock K8SLI-eSATA2 (ULi M1697) Intro 4/5
Bluetooth 27 Feb 2006
from
various
vendors
BIOS I
CPU Multiplier from 5x ~ 25x,
CPU Freq can be adjusted up to 340MHz
PCIe Freq can be fix at 100MHz or from to 90 ~ 170MHz
PCI Freq can be fix at 33MHz or from 33MHz to 37.5MHz
Processor Voltage can be increased up to 1.550v for FX-53. Different CPUs
will have different ranges. |
Memory can be set to run
the ram in ASync mode to the CPU CLK |
CAS Latency, tRAS, tRP, tRCD, MA timing, Burst length can be set to improve
performance. FLexibility option can be enabled to make the system more
compatible with RAM. |
