ASUS A8R32-MVP Deluxe
Review Benchmark 2/8
Benchmarks In this test, we measured the CLK used by the boards. The boards runs at 200.5MHz while the erst are ran at a slightly higher clk speed of up to 202MHz. Experiments have shown that a 1 or 2MHz difference will not show much improvements in 3D tests but CPU Arithemetic tests will result in a higher score. The following readings are obtained using CPU-Z.
The following are the memory benchmarks of the two boards in two different configurations. They're taken at CAS 2, 5-2-2, 1T cmd. All the boards seem to score almost the same. This is put here for completeness as we know the Memory controller is within the CPU. If there are problems with the BIOS settings, e.g. running at 2T as 1T, you wouldn't get a score of 6000+. So this tool helps us verify of and isolate any potential problem.
