 ASUS Striker
Extreme nForce 680 Review Benchmarks -
DOOM3 and Riddick
 Benchmarks - DOOM3 and Riddick For completeness, we emclose gaming benchmarks. As game demos or benchmarks are not 'quad-ready', it should not be seen as a weakness of the CPU. Once gaming applications are able to take advantage of quad cores, performance will generally be improved. We present DOOM 3 and Chronicles of Riddick.
 It can be clearly seen the difference between the two high end boards do not differ by a lot. In fact, it is only less than 1 FPS at 1600x1200x32.
 In Riddick, the score line shows that the Gigabyte GA-965P-DQ6 leads the both the ASUS Striker Extreme and ECS PN2 SLI2+ by just less than 0.1fps difference. Both are very close to each other in the scoreline.
 Next >>>  |
