FSB which is in QDR, the values are
actually multiplied by 4. Thus, if your CPU runs at 266MHz, it is 1066MHz
(quad pumped). The range is up to 3000MHz which is in fact the FSB range is
from 266 ~ 750MHz. |
The Memory clk can be set from 400 ~
2600MHz. |
CPU Multiplier can be set from 6x ~ 50x |
RAM timing adjustments. The familiar CAS
Latency, tRCD, tRP, tRAS, cmd rate are the most commonly used items are all
available for your tweaking. |
