DDRII Controllers ref voltage can be
increased for more stability during o/c |
If you have SLI Ready Memory, you can set
it to o/c up to 1 to 5%, MAX or EXPERT mode. |
ASUS Music Alarm is a non oc feature but it
is useful to use your PC as an alarm clock to play your favourite CD
everyday or selected days. |
The BIOS also allows you to save your
current settings into profiles. You can load the profiles for different
usage, for example, one for work and one for o/c (for games). |
