ECS
NFORCE 570 SLIT-A NF 570 SLI Intel Edition Conroe Mainboard Review Benchmarks
9/10
Benchmarks - RealStorm
This tool does realtime raytracing, a very
computational intensive application that does software rendering. Thus, it
requires high speed processors to do it. The author said "Of course
3D-Accelerators are getting faster too and evolve feature-wise, but beyond a
certain level of detail, a polygon has to be smaller than a pixel on the screen.
In this case, there is absolutely no reason to use polygon routines. So we
decided to use platonic solids combined with boolean algebra and raytracing. The ECS NFORCE 570 SLIT-A performed pretty well in this test which is more CPU intensive. From the results, we can see that in HOUSER test, the ECS NFORCE 570 SLIT-A isn't as fast as the rest of the boards tested. In RCMP tests, the same issue arises. Looks like the Intel chipsets does perform better in ray tracing compared to the NV chip.
