MEM Speed (DDR) can be set to run at the default 533/667 or
higher. The range allows one to run the DDR2 at DDR2-400 to DDR2-1300. Take
note that the specs only supports up to ASync DDR2-667. We tested the board
running CAS 5 DDR2-800, the system is not stable as it is already out of
spec. |
Over here, ram timings can be adjusted. In
our test, we ran in SYNC with CPU at CAS 3, 3-3-8, 1Tcmd. |
