ECS P4M800PRO-M V2.0 (VIA P4M800 Pro
chipset) for Core 2 Duo / Extreme Benchmarks 9/10
Benchmarks - RealStorm
This tool does realtime raytracing, a very
computational intensive application that does software rendering. Thus, it
requires high speed processors to do it. The author said "Of course
3D-Accelerators are getting faster too and evolve feature-wise, but beyond a
certain level of detail, a polygon has to be smaller than a pixel on the screen.
In this case, there is absolutely no reason to use polygon routines. So we
decided to use platonic solids combined with boolean algebra and raytracing. From the chart, we can see that both DDR or DDR2 takes almost the same amount of time to complete the ray tracing. As this application is not GPU bound, we can safely compare the results to our previous benchmarks of the 965p boards. For White, we get 1172, for the PX1 which is a dual channel architecture chipset, it scored 1206. For HouseG, P4M800Pro scored 460 whereas PX1 did 473. In HouseR, we get 5392 and PX1 scored 6864. In HouseV, we get 2540, PX1 scored 2904. In RCMP, we get 2370 while PX1 gets 2633. From the scoreline, we can gauge the performance difference between a single channel and dual channel chipset. Here is a breakdown :
