ECS PN2 SLI2+ (NV 680i) Mianboard Review Intro 5/5 Bluetooth 5 Dec 2006
Pricing of nFORCE 680i >>>
BIOS
CPU FSB voltage can be set to 1.5v. This is a bit limited as some of the 965P allows you to go all the way to 1.6v
Memory voltage allows one to set it up to 2.5v
For stability during overclocked environments, the South bridge voltage can be pumped up to 1.75v.
The same applies to the North Bridge, 1.55v is the max you can apply. Use the fan provided to help cool the NB.
HT Voltage can be set to 1.55v at the max.
Next >>> (Part II will come later)
