ECS PX1
Extreme (i965P) Review Intro 1/5
Bluetooth 17 Oct 2006
from
various
vendors
ECS PX1 Extreme
ECS is one of the major first tier mainboard
manufacturers in Taiwan. In the past, we always related ECS to entry level
boards. This year, ECS has been doing a lot more by introducing a number of high
end boards to the market. Some of them are for the Intel while some are for the
AMD platform.
Today, we will take an exclusive look at the
ECS PX1 Extreme. This mainboard is based on the Intel 965P chipset and ICH8DH
South bridge. It supports CPU LGA775 socket for Intel? CoreTM2 Extreme / CoreTM2
Duo /Pentium 4 / Pentium D /Celeron D Processors with FSB 1066/800/533 MHz and
Hyper-Threading Technology. In the near future, it will have a flash bios update
that will support the latest Quad Core processor from Intel.
The board supports 4 x 240-pin DDR2 DIMM
socket support up to 8 GB and supports 6 x Serial ATAII 3.0Gb/s devices with
Intel? Matrix Storage support (AHCI and RAID 0, 1, 0+1, 5 configuration).
Another on board Jmicron JMB363 1 x UltraDMA 133/100/66 for up to 2 PATA
devices, 1 x Internal SATA 3.0 Gb/s port, 1 x External SATA 3.0 Gb/s port.
The board also uses Realtek ALC885 for Intel
8-ch HD Audio, 2 IEEE 1394a ports by VIA chipset and Dual Gigabit Ethernet
Controller on board.
This mainboard also incorporates Qooltech, a
heatpipe design that keeps vital components cool by effectively directing heat
from the south bridge and north bridge to the rear. The board also supports
CrossFire using Catalyst 6.9 (16+4). With I.O.C, Instant overclocking is
possible with the board. It automatically detects the load and increase the FSB
for better performance.
The package also comes with a SATA to PATA bridge, ethernet cable, external
bracket for 1394, USB and multiple SATA cables.
Specification
CPU LGA775 socket for Intel? CoreTM2 Extreme / CoreTM2 Duo /Pentium 4 / Pentium
Support Hyper-Threading Technology
CHIPSET Intel? P965 & ICH8DH
North Bridge: Intel? P965
-- South Bridge: Intel? ICH8DH (Viiv)
MEMORY Dual-channel DDR2 memory architecture
4 x 240-pin DDR2 DIMM socket support up to 8 GB
Support DDR2 800/667/533 MHz DDR2 Memory
EXPANSION SLOT 2 x PCI Express x16 slot (Orange : x16 mode, Blue : x4 mode)
2 x PCI Express x1 slot (x1 or diabled mode)
3 x PCI slots
STORAGE Support by Intel? ICH8DH (ViiV)
-- 6 x Serial ATAII 3.0Gb/s devices
-- Intel? Matrix Storage support (AHCI and RAID 0, 1, 0+1, 5 configuration)
Supported by JMB363
-- 1 x UltraDMA 133/100/66 for up to 2 PATA devices
-- 1 x Internal SATA 3.0 Gb/s port
-- 1 x External SATA 3.0 Gb/s port
-- Support SATA RAID 0, 1 and JBOD
AUDIO Realtek ALC885 support Intel 8-ch HD Audio
IEEE 1394a VIA? VT6308P support 2 x IEEE1394a ports
DUAL LAN INTEL 82566DC Gigabit LAN controller
Realtek RTL8110S Giga LAN Controller
REAR PANEL I/O 1 x PS/2 keyboard & PS/2 mouse connectors
1 x Heat pipe heat sink for NB & CPU heat dissipation
1 x Serial port (COM1)
1 x External SATA port
4 x USB ports
2 x RJ45 LAN connectors
1 x Audio port (Line-in,4x Line-out, Mic_in)
INTERNAL I/O CONNECTORS & HEADERS 1 x 24-pin ATX Power Supply connector
1 x 4-pin ATX 12V connector
1 x Auxiliary 8-pin +12V connector
1 x IDE connector
1 x FDD connector
1 x IrDA for SIR header
1 x Speaker header
2 x 1394a headers
3 x USB 2.0 headers support additional 6 USB ports
1 x S/PDIF out header, 1 x CD-in header
7 x Serial ATA connectors
1 x 26-pin LPT header
1 x Front panel switch/LED header
1 x Front panel audio header
CPUFAN/NBFAN/SYSFAN/POWERFAN/AUXFAN connectors
SYSTEM BIOS Award BIOS with 16Mb SPI FLASH ROM
Supports Plug and Play 1.0A, APM 1.2, Multi Boot, DMI
Full support for ACPI revision 2.0 specification
FORM FACTOR ATX Size 305mm*244mm
