EPoX MF570 SLI (NV 570 SLI) AM2 Mainboard
Reivew Benchmarks 3/8
Benchmarks PCmark2005 PCmark2005 tests a number of important items in today's computing world. File Compression, Encryption, Decryption, Audio Conversion, Web Page Rendering, WMV Video Compression, DivX Video Compression, Physics Calculation and 3D, Graphics Memory etc. PCmark05 gives us an indication on how the system performs with effects from the bus system. Except the ASrock 939Dual-SATA2 uses a SATA I interface, the two other boards are using SATA II with NCQ. It is quite interesting to see the results as compared to other chipsets. Taking a look at non SLI mode, it scored 5055 which is the lowest among all boards tested. Yet in SLI mode, it scored 5266, which is much better than the rest.
