PCChips A33G (SiS 761GX) uATX mainboard Review
Benchmarks CPU CLK and Sandra 2007
Benchmarks The A33G runs at a default of 200.0 MHz on the dot. As you can see, most of the boards are not either slightly above by half a MHz or slightly lower. Although it might be half a MHz, it might give you very different results during the tests. Using Sandra 2007, the memory benchmarks are recorded, we found out that the PCChips A33G runs at 5819/5830. I suspect this is largely due to bandwidth allocated for the integrated graphics. The same situation happens to the ECS RS485M-M. Will this give us a lower score with an external graphics card?
