BIOSTAR
TF7050-M2, the mATX form factor HD Ready mainboard is ready to rock you off your
seat with its feast of functions, especially within the BIOS. Although small in
size, it has a full fledge BIOS that makes it a classic immediately.
Not only that, it is also the first board that
comes integrated with HDMI, D-SUB and TV out all in the back panel. This
definitely saves you a lot of time trying to find converters to convert DVI to
HDMI. The package comes with a HDMI->DVI converter which you can use for
connecting your HTPC to your current LCD screens.
Performance of this board is on par with other
7050-630a boards we tested earlier. We made a check on the BIOS, it seems that
the GPU CLK option is missing from the official bios we downloaded off the
BIOSTAR website.
Overclocking options are plenty for a mATX board. We were
able to POST to 300MHz. Stable at 295x10 with CPU Voltage pumped up by 0.1v. and
NB voltage increased slightly above the default. CPU VCore and VDIMM voltage can
be adjusted to insane levels but I would advise you not to do that just yet
unless you have adequate cooling like water cooled or LN2. It is to my surprise
the 7050-630a didnt' run as hot as most other boards I have tested. I suspect
BIOSTAR used a better heatsink.
Overall, this mATX board has is shockingly good in stability
and overclocking. Image quality produced playing back at 720p is pretty
impressive playing back 720p movies. Although it is out of spec, our H.264 TS
clip played back well within the CPU limits.
Pricing from
various
vendors
(US/UK)
- 7.1 HD audio
- HDMI interface
- HDMI->DVI converter
- TV Out at the back panel
- GbE
- Diagnostic LED
- Package did not include brackets for USB, LPT
- No 1394
- No external USB brakcets provided
Category |
Score |
Performance |
9 / 10 |
Features |
9 / 10 |
Ease Of Installation |
9 / 10 |
Overclocking Features |
10 / 10 |
Documentation |
8 / 10 |
Packaging |
8 / 10 |
Cost/Performance |
8 / 10 |
Overall Rating : |
8.7 / 10 |
