ASRock
4Core1333-FullHD ATi RS600/SB600 Mainboard Review Intro 2/5
Gallery
At the bottom left corner you will see the 4 red SATA II connectors supported by SB600. Near the SB is a 1394 controller chipset from TI. ClkGen is found next to PCI2 slot. On the right are 4 DDR2 DIMM slots supporrting up to 4 pc of DDR2-800. Total memory supported : 8 GB On the back panel, you will find the PS/2 Keyboard and Mouse, LPT1 port, DVI-D, D-SUB, 4 USB, 1 1394, 1 GbE and 7.1 ch audio ports.
