This is the CPU Configuration page where you set most of
the parameters of your system. Over here you can set the PCIe to run in
SYNC/ASYNC to your CPU. CPU Freq can be set from 100~650 MHz and PCIe can be
set from 80~160MHz. |
DRAM Frequency allows you to run the memory in ASync or
SYNC to the CPU CLK. |
